Putting AV components on top of a RPTV
Discussion in 'Archived Threads 2001-2004' started by Jason_H, Aug 21, 2001.
  1. Jason_H
    Jason_H Second Unit
    Mar 9, 2000
    422
    I had a thought today...am I committing a serious no-no by placing the majority of my components on top of my RPTV? I have a Toshiba 56H80 which seems like it has a quite sturdy cabinet, but could this be harmful? I do, at least, have the weight fairly evenly distributed across the top.
  2. Mike I
    Mike I Supporting Actor
    Jan 20, 2000
    720
    I have had components on top of my 56x81 for over a year and half now and no problems at all..I just dont have the room for a component rack because my set sits kitty corner in the corner of the room due to a fireplace....
  3. errol
    errol Stunt Coordinator
    Dec 29, 1999
    150
    Hi Jason,
    The bulk of the weight of the 56/65 tosh sets is due to the cabinet. The cabinet is solid and rigid. No need to worry about putting a few components on top.
    I wouldn't do this on its sister 40 tosh though as it is the not constructed the same.
    I would highly recommend a separate cabinet though for your components rather than putting them on top of the set. Ideally, you'd want to only put your center speaker on top.
    Errol
    Keohi HDTV
    Your Friendly HDTV Tips Site
  4. Jason_H
    Jason_H Second Unit
    Mar 9, 2000
    422
    Thanks for the help, guys!
    Yes, I would very much like to put a cabinet or a rack next to the TV for my components, but I do not have the room at the moment (in an apartment). This is definately something I will do in the near future. Thanks again!
