Pushed in tweeter
Discussion in 'Archived Threads 2001-2004' started by Tom Garvey, Aug 22, 2002.
  1. Tom Garvey
    Tom Garvey Stunt Coordinator
    Jan 28, 1999
    122
    Leaving it pushed in.. Does it affect the sound?
    If I poke a needle in it to pry it out.. does that pin hole affect the sound?
    Need to know...
  2. Joe Tilley
    Joe Tilley Supporting Actor
    Jan 1, 2002
    686
    Tom, depending on what the tweeter is made of a piece of electrical tape works perfect most of the time to pop them back out. As for effecting the way it sounds I'm sure I would have a negative effect on it. If it was me I would try to get it worked back out with a piece of tape if you can, if that don't work use a small pen with a slight bend in the tip to use as a hook.
    Oh & with the tape thing it has always worked best for me when you stick the tape into the dinted area only & pull straight out quickly & it should come right out.
    Good luck[​IMG]
