Mike Nelms
Grip
- Jul 19, 2002
Hi all,
I had my 47WX52 serviced today under warranty for a screen problem...that's solved. The tech that was here mentioned that he thought Panny has an extension rack (shelf) that can be mounted to the top of the set to hold a/v equip. There are 3 holes along the top of the back of the screen and a hole on each side of the back of the screen that are not used. Not sure if he is correct in his statement or not. I did call Panny and ask they said they'd get back to me.
Anyone have any ideas? Heard anything?
Thanks for any help!
Mike
Mike
