PT-47WX42 convergence
Discussion in 'Displays' started by AllanN, Jul 21, 2003.
  1. AllanN
    AllanN Supporting Actor
    Mar 15, 2002
    950
    I was doing a 6 month calibration of my system. And when I was setting the internal convergence on my set I decided to use a crosshatch pattern to get a more accurate setting. I was using the crosshatch pattern off of Sound & Vision Home Theater Tune-Up.
    I could never get the crosshatches and the internal settings to match up on the sides. This was only the case when I had the the TV in FULL mode in 4:3 the crosshatch pattern matched up to the internal settings. I did find that my coarse (Convergence 1 on the panny) was pretty far off when I put up one of the anamorphic over-scan patterns. Fixing this helped a little.
    On some grey test patterns I also noticed a red line at the far right of my set and a blue at the far left. But my convergence settings where set as close as I could get them for the rest of the screen.
    Has anyone else run into this issue? Does anyone have a set procedure for setting convergence on the PT-47WX42 or any other similar set.
  2. RenoV
    RenoV Agent
    Mar 7, 2002
    41
    Sounds like you need to do a fine convergence adjustment in the service menu. It's definately not for the faint of heart, so I highly suggest against it if you're unsure... but you can go to www.panny.tv for details on what to do.
