PSP owner, needs usb drivers for win98 ASAP!
Discussion in 'Computers' started by Sean Moon, Mar 24, 2005.
  1. Sean Moon
    Sean Moon Cinematographer
    Jan 25, 2001
    2,041
    I am poor and have an old computer with Windows 98. I am trying to connect my psp to the computer through usb but am unable to have it detect. Reading things it says I need a file called usbstor.sys to work. I have downloaded this file, but dont know where to put it or anything. HELP! ASAP!
  2. Gerald LaFrance
    Gerald LaFrance Supporting Actor
    May 28, 2002
    510
    Earth
    Gerald LaFrance
    Hi, Are you having trouble getting the USB working or the PSP to work(what is a PSP)??
    If you are trying to get the USB working you need Win 98 SE!!
  3. SethH
    SethH Cinematographer
    Dec 17, 2003
    2,867
    Portable PlayStation. Anyway, Gerald is right, you'll need 98SE to use USB.
  4. JoshuaML
    JoshuaML Extra
    May 28, 2003
    23
    98SE? Funny, it worked fine for me in win98 using my usb key drives and my scanner. One of the flagship features for 98 was its support for usb (which was first available in win95 OSR2) He should just need a driver for it
  5. Chris
    Chris Lead Actor
    Jul 4, 1997
    6,788
    Look for the Unofficial SP1 for 98SE (type it into google) download.. install.
  6. brentl
    brentl Cinematographer
    May 7, 1999
    2,921
    110
    Also probably on the Win98 disc in a USB folder. Probably even an EXE file to install.
    Brent
