PS2 DVD weak audio signal? (1 Viewer)
Joseph_Mikhail
Does anyone else have a problem with the audio signal from the PS2 when watching DVDs? To get an adequate sound level, I have to crank up the volume to -10 dB. Seems really high.
I don't have this problem with other AV sources.
ChrisMatson
Iowa, USA
Chris
Although my PS2 was stolen :angry: and I haven;t used it for playing DVDs in some time, as I recall there is a volume option in the PS2 setup menu. Check the owner's manual.
OttoIsHere
