andy_brehm
- Oct 10, 2001
hey all. i just recently ordered a infocus x1 for dvd and ps2 use. right now i am still using the composite cable out of the box for the ps2 but i know that there are s video and component connections for the ps2. when i get the x1, i have a couple of options on hooking everthing up and i was wondering if you could advise me which would be the best. okay, now to get started....
i have a jvc progressive scan dvd player (not sure of the model number right now, i can get it later if it helps) that i have hooked up to my yamaha rx-v1000 reciever which is then hooked up to my panny rptv all via component cable.
when purchasing the x1, i also got the component to vesa adapter. no here is where i have some options. i might keep the dvd player hooked up to the reciever instead of a direct connection to the projector so that i can buy a component cable for the ps2 and hook it up to the reciever through a D-TV or whatever the other component input is on the back. then i can send a single component signal to the projector from the reciever.
my other option is to hook the dvd player directly up to the projector via component cable, then buy a s video ps2 cable which would probably go to my reciever then go to the projector through the s video monitor out.
my question is, which setup would give me the best picture quality from both sources? with a larger picture (100") i want the best signal sent for the best picture but im not sure what way is the best to go about that.
also, on a side note, should i send a progressive video output from the dvd player to the projector through the vesa adapter?
thanks
andy
thanks
andy
