Brian OK
- Aug 29, 2000
For Sale:
PS Audio 6 outlet Juice Bar power strip. This high quality power strip uses three PS Audio Power Port receptacle (they sell singly for close to $50. each!)
Specs are 120-240v, 50/60Hz, 15 amp maximum.
15 amp IEC (so you can ditch the supplied 3' molded power cord and substitute an aftermarket cord of better quality). This unit does not contain any filtering and will NOT be current limiting to your gear, as each outlet is star wired. It is hefty and built like a tank.
Asking $120. obo, shipped, to anywhere in the US only.
Excellent condition (albeit two barely noticable abrasions to the powdered gray metallic enamel paint near the middle receptacle. These are not scratches, do not penetrate the paint, and could be rubbed out if you had a mind to).
see www.psaudio.com for more info and user comments
BOK
BOK
