Proven Dual Tempest Designs?
Discussion in 'Home Theater Projects' started by Martin Rendall, Sep 14, 2004.
  1. Martin Rendall
    Martin Rendall Screenwriter
    Dec 5, 2000
    1,043
    Hi,
    I've searched around a fair bit, and have found some references to dual Tempest designs, but unfortunately most times I end up finding dead http links.
    I'm curious to know of any proven dual sealed low Q designs. I could try to design one myself with software, but I'd much rather follow a tried and true design. What sort of performance improvements would I see?
    Martin.
  2. GrahamT
    GrahamT Supporting Actor
    Sep 13, 2003
    556
    What about two EBS alignment Tempests, that would be more flexible. One, dual Tempest low Q sub will weigh a few hundred pounds.
    To answer the question, I believe James W Johnson designed a sub dubbed the Big Pig, he may still have the plans, or contact Dan Wiggins at Adire.
  3. RodN
    RodN Stunt Coordinator
    May 9, 2004
    58
    Why not just follow the low Q design from the whitepapers then mount one sub on top of the other?
  4. Allen Ross
    Allen Ross Supporting Actor
    Sep 30, 2002
    819
    well if you do a push pull combo you will bring the THD down so thats a benefit.
  5. Martin Rendall
    Dec 5, 2000
    1,043
    OK, how about this: build one low-Q or mid-Q sealed sub, and if I think I need more, build an HT targeted sub specifically for the LFE channel.
    Thoughts?
    Martin.
