Proud new Tube Papa, My impressions.. (1 Viewer)
Brett DiMichele
Brett
It's been a fairly long wait...
I ordered my Antique Sound Labs Wave AV-20DT (Dual Tube's)
over a month ago from Kevin at Upscale Audio and it was a
wonderful transaction fully. He kept me up to date with
details at all times and while it took longer than expected
they arrived in tact (Considering they had to make thier
way from China to Canada to California to Pennsylvania).
Initial Impressions..
I don't have the tubes biased correctly because my multi
meter doesn't read high enough... I need to go out and buy
a new one tomorrow..
I haven't let the tubes burn in like most people do but
already the sound is impressive. I notice more decay on
instruments than I did on my solid state amps, a well known
guitar piece sounds completely new to me as the strings can
still be heard vibrating longer than I ever could before..
I get a little hum with the volume at 20 and no source but
part of this is that I just quickly threw them where ever
I had the space(I need a new rack!).
They put out 20 watts and this drives my speakers nicely as
I expected but even into clipping they STILL sound good!
Are they on par with multi thousand dollar tube gear? surely
not.. But for $500.00 for a pair of 20 watt Monoblocks running
dual 6L6's on the output stage and a single 12AX7 on the
input they sound extemely pleasing!
Kevin T
thanks for the quick review, brett. i am considering purchasing the asl wave av-20dt's as well for a 2 channel bedroom system as i have no experience with tubes and really prefer the solid state i own for my main system. for the price of admission, the asl's are very attractive in my opinion. i look forward to future postings on the asl's.
kevin t
Mat_M
Sounds pretty sweet! Keep us up to date when you place them where you want them and after you're done with burn-in.
Brett DiMichele
Brett
Chu,
Well it's hard to compare the Tube Ultra-Q to the ASL's for
the sheer reason that the Behringer uses the 12AX7 as a
pure linestage device where as the ASL's have the 6L6 Tubes
coupled to the speakers on the output side and they are
actively riding the impedance swings of the drivers.
The ASl's definatly add a more noticeable "Tubey" ness to
the music moreso than the Behringer but that's not to say
that the Ultra-Q doesn't add tubey qualities either.
When I get my Parasound Halo P3 PreAmp next month I look
forward to using the Tube Ultra-Q in a pure ballanced
connection to the P3 and then out to the ASL's (unballanced).
I feel that all 3 units will work well together and being
able to use the parametric eq function of the Behringer can
always come in handy for taming peaks.
The ASL is well constructed for a Chinese piece of audio
equipment. It lacks the high end frills found on something
like the Cary Rocket 88's which have all sort of very nifty
features. With the ASL's you have to manualy bias the output
tubes but it's simple, they provide you with the output taps
to connect the multimeter to and then you just simply turn
each respective tube's Pot till you hit the 330Mv range and
you're good to go (you can be +/- 5% variance) and I am sure
you can overbias the tubes if you want (shorter tube life).
The only thing the ASL's won't do is drive a 4 ohm load (or
atleast ASL doesn't say you can... As beefy as the amps are
would it really hurt?)
I plan on doing some mods to them.. These are keepers even
if I do upgrade to something very high end in the distand
future.. (something like Cary...) :)
Scott Oliver
I had a friend's Wave-8's driving my Offrandes which are a 4ohm load and 89dB senstivity rating. The Wave-8's drove them to 90+ dB peaks without clipping. The Offrandes are considered easy to drive speakers because the impedance load basically stays at 4 ohms throughout the entire range, so maybe other 4 ohm loads will be different. But the Offrandes did blow a fuse (Thnakfully this went before a channel) in my SS Harman/Kardon 2.1 5-ch amp that was suppossed to be able to put 180 watts into 4 ohms. Cheap **** amp!
Brett DiMichele
Brett
Scott,
I am glad to hear the Wave8 handled 4ohm I see no reason
why the AV20's would not do the same. They are a more
robust design with heavier components (and better components
throughout)
Now if I could just get the dang things biased right..
*shrugs* I don't think my Multimeter is going to do what
I need it to do.. A trip to Rat Shack may be in order!
Ohh and I was already looking at new tubes.. PE has some
nice ElectroHarmonix 6L6's under thier EH line cheap like
$20.00 each and the EH Line 12AX7 is only 9 bucks! :)
Chu Gai
*groan* and tube stabilizers, socks...sheesh. go on, trade that vette in and get one with a carb..that's what you're looking for, you know it :)
Brett DiMichele
Brett
Chu,
Naw got one of them old one's too (68 coupe) :)
I love both old and new technology. I have no idea why I am
so nostalgic.. Being only 26 I never saw any of this stuff
the first time around.. But that don't stop me from loving
it! :D
Michael R Price
Sounds nice Brett... your description is somewhat similar to what I noticed with my Zen amp. Keep up those improvements!
Brett DiMichele
Brett
Mike,
Yep I would imagine the Zen and Wave's both impart similar
charecteristics on the music.
They are starting to get burnt in and the sound is even
better than out of the box. Dare I say Tubes are one of the
few things I believe "burn in" takes place with.
I think the Waves could be even better if all the caps are
replaced with the best paper/oil caps out there and a better
set of output tubes and a better input tube.
The factory installed output tubes are of unknown manufacture
they just have ASL's logo on them (I assume they are chinese?)
and the output tube (suposed to be a 12AX7 but says ECC38)
is a JNJ.
But all in all for the money it's got good components inside.
It has Illusion Oil Filled Caps on the critical locations
and regular caps elsewhere.
I will scan in the schematic and post it here for you to
scope out.
Brett DiMichele
Brett
For anyone curious as to what the Wave AV-20DT's look like
here is a picture from Divergent Technologies web site.
Divergent Tech is the main distributor for ASL they are
based in Canada. Upscale Audio (Kevin Deal) carries ASL as
does Adire Audio in the U.S.
MODEL WAVE AV-20 DT
OUTPUT POWER 20w
Frequency Response at 1W 20Hz--25000Hz + 1dB
Frequency Response at full power 24Hz--25000Hz + 1dB
Distortion at 1W
Chu Gai
It's not a mod, and lord knows people swap this brand of cap for that one, with nary hard data to be found, but have you perhaps considered making some sort of enclosure for those tubes? Something that might dress it up a bit. Wood, Corian, etc.?
Brett DiMichele
Brett
Chu,
Heh yeah buddy! I sure have thought about it..
They come with Tube Cages (which I don't particularly like)
I do plan on adding some real wood along the sides and I
have some nice billet aluminum "rack" handles that match
the finish of the face plate to the T and I am going to
add those to the top lip of the face plate to protect the
tubes from being bumped (or protect hands from being burnt).
Also.. And I know some may think this is cheesy.. I am
replacing the red power LED's with Blue one's :)
Chu Gai
i've done that with instruments...replaced led's and all...but you know Brett, if you think this out a bit, maybe look at some of those tube links i gave you a while back, some elegant ideas might come to you that you can adopt and really give it an 'art deco' look or something. Being that you've got an interest in cars and all, thoughts of chrome (black chrome), anodizing, powder coating all come to mind. Of course you'd need to find some way to get the metal work done, but maybe you've got a friend with some access to aluminum stock. Personally, I was thinking of something that both would be contained in and to make it a bit wider.
Brett DiMichele
Brett
Chu,
Nah I do not want to combine the Mono's into one chasis that
defeats the purpose of having Monoblocks :)
I do want to keep the chasis's seperate but I am certain
that I can spruce the existing cabinents up some with use
of wood.
It's something I have to think about.. I allready have an
idea that would look sharp I may have to model it in 3D
first just to make sure I like the look.
Brett DiMichele
Brett
As promised I scanned in the Schematic for the AV20-DT if
anyone (Mike)cares to DIY these..
Speaking of Mike.. Since you seem to know electronics and
I don't particularly know squat about them.. Anything you
see out of the ordinary here?
Here is the link (the image is too big to post here..
http://www.westol.com/~brettd/temp/schematic.jpg
Brett DiMichele
Brett
It's been a wonderful week plus full of adventures in tube
audio. The tubes are officialy burnt in and the sound of the
amps is amazing to put it mildly. The Midrange is now more
natural than ever no loss in punch but a definate gain in
liquidity as they audiophiles say.. The Trebbel is also
more smooth but with no loss in detail, there is no upper
roll off on these amps but everything is just much more
pleasing for sure.
Later down the road I will upgrade to better tubes and see
what if any difference those may make but for now it's pure
tube heaven!
(The best purchase I have made to date..)
DashAsh
