Pros and Cons of Front vs. Rear porting
Discussion in 'Archived Threads 2001-2004' started by Mark Fitzsimmons, Jul 5, 2002.
  1. Mark Fitzsimmons
    Mark Fitzsimmons Supporting Actor
    Aug 18, 2001
    539
    I curious as to the differences of front and rear porting. My speakers (JBL S26) are front ported but other popular speakers are rear ported like the Paradigm Mini Monitors for example.
  2. Jason Wilcox
    Jason Wilcox Supporting Actor
    Feb 21, 2002
    652
    you can make a great front ported speaker and a great rear ported speaker.....no real difference in my mind
    what bothers me is people who try to steer clear of rear ported speakers because they shouldn't be placed next to a wall.....no speaker should be placed next to a wall!
  3. felix_suwarno
    felix_suwarno Screenwriter
    Dec 2, 2001
    1,523
    "no speaker should be placed next to a wall"
    why do they place speakers on the wall in theaters?
  4. Jason Wilcox
    Feb 21, 2002
    652
    ahh sorry....i shouldn't have said it as an absolute rule.....more like a majority of the time thing.....usually just makes the sound "boomy" and "bloated"
    i don't really see it as a necessity to stick away from the walls for surround speakers as they don't get that much action anyway ('cept for multichannel audio)
  5. Sebastian
    Sebastian Second Unit
    Apr 14, 2002
    361
    You just don't want the port that is in the rear of the speaker enclosure to be facing too close to a wall. I think 6" is good enough.
  6. Mark Fitzsimmons
    Aug 18, 2001
    539
    My mains are front ported and have about a foot between them and the wall, this sound like good placement?
    And if placing next to walls creates boomy bass, then why is it recomended to put subs in corners?
  7. Brian Fellmeth
    Jul 30, 2000
    789
    Damn good question Mark. Boomyness is caused by a spike in the frequency response around a narrow band. When the source material plays through the spike, the bass suddenly jumps out of the soundfield. Placing main speakers close to walls increases the risk of a room induced spike toward the bottem of the sattelites range (80-200 Hz). The difference with a sub is that corner loading has the effect of amplifying all frequencies. The FR of a sub will be lumpy in any untreated room in any location. Putting it in a corner may make it lumpier or flatter. The advantage is that it will be louder at almost all frequencies. ITs like the corner is acting like a megaphone.
  8. Mike Veroukis
    Mike Veroukis Second Unit
    May 8, 2001
    455
    Canada
    Michael
    I should also point out that putting the sub in the corner is not always the best place for it. For example, if your room is a perfect cube placing it in the corner is probably the worst place for it.
    Check out this link for a good way to pin point the best location for your sub.
    Here's a link for proper speaker placement.
    - Mike
  9. Mark Fitzsimmons
    Aug 18, 2001
    539
    I think my speaker and sub placement is pretty solid. My placement goes hand in hand with the recomendations of audioholics. I did test sub placement and in fact corner placement is best in my room.
  10. matthew_rm
    matthew_rm Second Unit
    Dec 24, 2001
    379
    Real name
    My Klipsch RF3's are about 2 feet from the walls in my bedroom. They are not boomy. (Very clean and deep) When 6 inches from the wall the don't sound to good.
  11. ChrisAG
    ChrisAG Supporting Actor
    Aug 26, 2001
    503
    I agree - 6" is too close for mine also (Mordaunt-Short 902 bookshelfs used as surrounds), but I can't move them further out without affecting other furniture. I'm guessing that a minimum of 9" is necessary to avoid the bass spike with bookshelfs, though 12" would be ideal.
