Richard_Fuentes
Grip
- Jun 5, 2005
hello everyone,
i just got back up my sub which was being repaired, which i dropped off 5 weeks ago, from a&b sound.
and i was wondering if you guys can give me some advice on subwoofer and receiver settings (crossovers, volume levels, etc.).
i have the velodyne deco 7.1 system which is being juiced by an onkyo tx-nr901 av receiver (110w X 7 @ 8ohms).
i presently have the subwoofer level at a little less than half on the sub. there is no subwoofer volume on the receiver. although the db level is set to 0 along with all of the satellite speakers. i'm using the crossover on the receiver, which is set to 120hz. if i use the receiver crossover, does it automatically override the built in crossover on the sub? does it matter what the crosserover is set at on the sub or should i set it to something higher or even all the way up or the same as the receiver?
and i was wondering how i can break in the sub? i've heard that it isnt necessary to break them in. and some people recommend it. if its beneficial for the sub to be broken in, where can i buy a break-in/burn-in cd?
your advice would be greatly appreciated. please and thank you very much.
