Proper speaker wiring question?
Discussion in 'Archived Threads 2001-2004' started by Bolivar G, Aug 17, 2002.
  1. Bolivar G
    Bolivar G Second Unit
    Jul 9, 2002
    318
    Do the lengths of the mains and center have to be the same length?? Say one speaker is right next to the reciever and the other one is well away. Do still make them the same length even thou you will have a bunch of wire laying on the ground??
    And also do the surrounds have to be the same length also??
    Or will the lenghts not matter at all?? Please help, wiring my system this weekend to better wire.
  2. Robb Roy
    Robb Roy Supporting Actor
    Jul 15, 2002
    711
    Over short distances, it probably won't matter, but I always make certain my mains and center have identical lengths, as well as my surrounds. I also like to have some extra length to play with speaker positioning more easily.
  3. Bolivar G
    Jul 9, 2002
    318
    Thank for the reply Robb.
    Is having a bunch of speaker wire coiled on the ground bad??
  4. John Garcia
    Jun 24, 1999
    11,571
    25
    NorCal
    There is no reason or benefit to having the mains and center the same length.
    Avoid coiling extra wire.
  5. Chu Gai
    Chu Gai Lead Actor
    Jun 29, 2001
    7,270
    the lengths are not an issue but i'd leave a bit extra to allow for future repositioning. coiling the wire makes no difference with regards to the sound.
  6. Brian Fellmeth
    Jul 30, 2000
    789
    Chu is probably correct about the coiling in the real world, but it is hypothetically possible to add undesired inductance to speaker cable by coiling it. It would probably take 10 plus loops around a tight radius for this effect to be audible, but why take the chance ? There is absolutely no benefit to equalizing speaker wire legnth.
  7. Pete Jennings
    Pete Jennings Second Unit
    Sep 13, 1999
    333
    110
    The ONLY advantage to having your wires the same length is in re-sale value. I guarantee you that people will shy away from buying different length wires from you should you decide to sell in the future. [​IMG]
    My $.02
    Pete
  8. Chu Gai
    Chu Gai Lead Actor
    Jun 29, 2001
    7,270
    I posted the following some time back...
    Inductive coils are made by coiling a 'single' wire and current flows in one direction only. A speaker wire is composed of two wires, generally in parallel, and the current that flows in the two wires is both equal and opposite. Any electromagnetic fields that are present basically cancel out so that any inductance in the coiled wire would not differ to any significant degree from the uncoiled wire.
  9. Bolivar G
    Jul 9, 2002
    318
    Thank for the answers everyone.
    Wired up my system this weekend. The lengths are not all the same but I left enough slack for repositioning and moving speakers around for cleaning around them.
