Hello all,
I am getting my final design ideas for my dedicated home theater and was wondering what the proper screen size and resolution for a front projection system would be for my room?
I have the framing up and it is about 19'6" X 12'3" X 8' with a 1 foot platform for elivated seating for the second row. The first row will be about 8' to 9' away from the screen and the second row will be about 14' to 15' feet away. The room will also be completely controlled lighting.
Also too if you could recommend screens and front projectors that match the criteria required for my room setup I would be eternally grateful.
Thanks in advance for your help.
