"Prop walls" for trying out different things...
Discussion in 'Archived Threads 2001-2004' started by MickeS, Mar 8, 2002.
  1. MickeS
    MickeS Producer
    Jul 24, 2000
    5,058
    OK, I couldn't figure out a good subject line, sorry. [​IMG]
    I was wondering if anyone knows a way to make cheap, lightweight "prop walls", in other words walls that I can use to try out different solutions in my house. The walls do not have to look good, they don't have to "work" as walls, they just need to be something I can put up in order to get a better idea of what to do (I'm thinking of closing off a room).
    Anyone got any ideas...? I was thinking something with some kind of foam/cardboard material, but unsure of how to get it or what to get.
    /Mike
  2. Billy Posey
    Billy Posey Second Unit
    May 15, 2001
    255
    The only suggestion that I can make, is for you to go to a local home improvement store and check out those artificial walls that they use to show off products like windows doors frames etc. good luck
  3. Scott Jelsma
    Scott Jelsma Auditioning
    Feb 27, 2002
    14
    You can get 4'X 8' sheets of 2" styrofoam at your local home improvement center. They are inexpensive, light weight, and easy to cut with a utility knife. They would make great "prop" walls.
  4. Pam W
    Pam W Stunt Coordinator
    Jan 3, 2002
    89
    I suggest the same thing as Scott - they are in the insulation section of the home improvement stores. I have seen tham in light blue or pink. They are lightweight, can be cut with a knife, and can be used for other projects later! Here in NC they run between $10 and $12 as I recall. Good luck with your project!
