Pronto won't boot -- stuck
Discussion in 'Archived Threads 2001-2004' started by Thomas Carstensen, Aug 9, 2002.
  1. Thomas Carstensen
    Thomas Carstensen Auditioning
    Aug 30, 1999
    13
    Tried to hard-reset the pronto (TS1000) buy using a paper clip. Reboots to:
    "Invalid config file - restart will use original..."
    only option is to press restart -- i do -- comes back up
    to same invalid config file screen -- forever and ever.
    Software to update firmware fails cuz it can't boot up at all. Can't even download old config file.. nothing.
    it's totally in a screwed up loop of death.
    all faqs online no help -- any ideas or references?
    thanks
  2. Frank Doorhof
    Frank Doorhof Stunt Coordinator
    Feb 16, 1999
    54
    Remove the batteries and THAN upload new CCF's.
    Should do the trick.
    Greetings from Holland,
    Frank
  3. Thomas Carstensen
    Aug 30, 1999
    13
    i tried that -- now it boots to a blank screen -- nothing.
    Trying to down/up load or install the lastest firmware fails now cuz the pronto will not respond...
    hitting the reset button causes it now to also boot to a blanks screen -- it's really screwed up i think
  4. Jim Lenneman
    Jim Lenneman Stunt Coordinator
    Apr 7, 2000
    152
    Thomas,
    This problem is not all that rare. It's a timing issue. During the download, you must catch the remote at exactly the right time in order for it to work. It can be very frustrating. There is a third party program called "Tonto" which is available here: http://giantlaser.com/tonto/. Incorporated in this program is a "Pronto undead" feature which has been sucessful for many people experiencing your type problem.
    Jim L
  5. ward.p
    ward.p Auditioning
    Sep 11, 2002
  6. Lee L
    Lee L Supporting Actor
    Oct 26, 2000
    868
    Also, have you tried www.remotecentral.com in the online FAQ's you mentioned. There is something in their FAQ about using hyperterminal to revive a stuck Pronto, not too sure of the details cause I've never done it but I have seen posts from people who said it worked.
