Pronto TSU 2000 software not XP compatible?
Discussion in 'Archived Threads 2001-2004' started by Scott Yuri, Feb 22, 2002.
  1. Scott Yuri
    Scott Yuri Stunt Coordinator
    Dec 5, 2001
    106
    I have heard that the editing software for this remote is not Windows XP compatible. Can anyone verify this? I'm in particular speaking of the RAV-2000 from Yamaha.
  2. Paul Padilla
    Paul Padilla Supporting Actor
    Jan 15, 2002
    767
    I can only speak as a Pronto user...but
    Pronto edit works fine with Win2k and XP. The problem people have been having is the program crashing while learning codes while attatched to the computer. Sometimes it works fine, others it generates errors and closes the program. There are tons of info on this subject at http://www.remotecentral.com
    General consensus seems to be..."always learn codes directly into the remote while unattatched to the computer. What I've taken to doing is adding a hidden panel for each device that only has IR codes. Then using an alias for each button pointing there. That way I can do all the learning without the software.
    Good luck.
  3. ChrisB
    ChrisB Stunt Coordinator
    Apr 3, 2001
    94
    I have XP and it works fine, I did have to make sure the patch cable was in Com port 1, or change it to Com port 1. XP did give some warning when I was going to install pronto edit, some digital signature thing, I ignored it and it works fine.
  4. RandyRush
    RandyRush Stunt Coordinator
    Dec 11, 2001
    61
    I too, use xp as well as win2k; PE works fine on both
