Adrian_S
- Apr 29, 2002
Hi All,
I am looking for a new remote for my media room/theater. This is what I have priced:
TSU-500 - $169
http://www.etronics.com/product.asp?...00&showspecs=1
or
TSU-2000 $$219
http://www.etronics.com/product.asp?...000&SVBName=30
I would like to be able to control 10 devices and have the flexibility of recreating most of my remotes with the software included. Keep in mind that this will be new to me, and I would like my remote to work as much as possible out of the box. My equipment is not fancy, most JVC, Sony, Pioneer and Toshiba.
Since the only remotes I used are the HARD button type,I don't have any experience with these type of LCD remotes. I was hoping some of you who do own these types of remotes, could give me some advice.
My main concerns are:
- How many devices can I control?
- can this remote learn from other remotes?
- Will I be able to recreate a single remote entirely (all buttons and functions)?
- Will this remote work with my TiVO?
- will it work with my digital cable?
- How much programing is it going to take me to get it to work?
- Should I get an extended warranty for this type of remote for 34.00 dollar (2 years).
Thanks for any help you provide..... Just a note, if the LCD type of remote is not for me, then my next choice is the MX-500.
TSU-500 - $169
or
TSU-2000 $$219
