Pronto Question: Serial Port Coupler?
Discussion in 'Archived Threads 2001-2004' started by Oswald Pascual, Feb 18, 2002.
  1. Oswald Pascual
    Oswald Pascual Second Unit
    Jun 30, 1997
    299
    My Sony VIAO Laptop does not mate properly with the Pronto TSU-1000 cable. I think the PRONTO is using an RS-232 cable for communications. Both the Pronto cable and my laptop inputs are female! If I get a coupler will this work with my laptop, or is there another option. possible using my USB port? Help Needed... Thanks
  2. Arthur Legardo
    Arthur Legardo Second Unit
    Jul 21, 1999
    441
    Try the coupler, there has been a lot of discussion over at Remote Central about connecting a Pronto via USB. To sum it up, it is possible, but it was more trouble that it was worth.
  3. Oswald Pascual
    Jun 30, 1997
    299
    Thanks Arthur, I have read that thread at remote central, but I was hoping that someone has tried the coupler thing already to see if it worked. That USB sounds like a pain so I wont bother trying that. I see no other way of programming my remote with my laptop if the coupler does not work. I was just hoping to hear some positive news on the coupler.
  4. ChrisB
    ChrisB Stunt Coordinator
    Apr 3, 2001
    94
    I have a Compaq 2701US with the same thing, I bought a Keyspan USA-19QW and it worked fine. Just make sure you change the USB port to COM1 or it wont work(at least it didnt with mine). I picked mine up a Comp USA for around 59 bucks. I looked at it as a good investment, if I want to go to a customers house and program there remote, I can use my laptop.
