Pronto Edit questions regarding adding Channel Bitmaps and actions
Discussion in 'Home Theater Projects' started by Ronald Epstein, Jul 23, 2003.
  1. Ronald Epstein
    Ronald Epstein Founder
    47,653
    5,051
    Two problems....
    First, I managed to add BUTTONS with BITMAPS of
    specific channels to my Pronto CCF layout using
    Pronto Edit 4. Not sure why, but I entered the
    same bitmap for each of the 2 ACTIVE and INACTIVE
    windows in the logo fields.
    Everything shows up nicely within ProntoEdit, but
    when I downloaded the CCF to my Pronto, there were
    NO IMAGES showing up. Just totally blank fields.
    Did I forget to check something in order to
    activate those image files?
    Next....
    Any way I can program the new channel buttons
    with the number locations (such as HBO 501)
    within ProntoEdit? In other words, assign #501
    (channel numbers) to the HBO image?
    If so, can someone lay out specific instructions
    to do so?
    Thanks so much in advance
  2. Jeremy Little
    Jeremy Little Supporting Actor
    Jun 9, 2001
    770
    Ron,
    Buttons that have no command assigned or learned to them are invisible to the Pronto. If you haven't assigned the numbers like you stated in the second half of your post, this is more than likely your problem.
    For HBO #501 (assuming the basic functions for the DBS is already programmed in), you got to button properties and select Alias > Device(DBS?) > 5. Next you choose Alias > Device > 0. Then select Alias > Device > 1. Lastly, select Alias > Device > Enter to make it tune to the station right away. In the white command box, you should now have 4 lines of commands. The next thing is to try it, because your box probably needs a delay between each button press so your box will cnot skip commands. Luckily, you can add those later and re-arrange the commands in the white box just by dragging them up or down.
  3. Ronald Epstein
    47,653
    5,051
    Worked like a charm!
    I can't thank you enough.
  4. Jeremy Little
    Jun 9, 2001
    770
    Great to hear.
