Projector under $1800 (1 Viewer)
Christo Ramo
I am going to pull the trigger on a projector, but I was wondering what to look for? I would like to be able to have a screen size around 50 inches and would like to have connections to a computer.
thanks.
KirkP
Christo, so you'll only be connecting to a computer? What type of content will you be displaying? Computer applicationa or video over PC? Is there a reason you only want a 50" screen? Consideration should be things such as the projector resolution to match your source, brightness to support your environment, and the desired inputs to name a few.
Jim Mcc
Oconomowoc, WI.
Jim
Christo, no offense, but to use a projector with a 50" screen is kind of silly. It goes against all the reasons people buy a projector(big screen and movie theater experience).
Peteo
