Melissa_
- Jul 21, 2005
I need some expert advice, but in lemans terms (please!)
My dedicated home theater room is 13'6"W x 20'L x 8'H with 0-ambient light.
I am looking at either the Sanyo Z4 or the Panasonic 900U but need to know if either will work to allow me to put a 109" (16.9) screen (Da Lite Cinema Contoure) in the front with a throw of only 12.5-14'?
My problem is that the room was pre-wired by the guy we bought the house from and the projector/power wires are cut through at a 12-14' throw.
Will either of these projectors accomodate that throw/screen size?
Any advice/comments/recommendation are appreciated.
Thanks.
Mel
Thanks.
Mel
