Mike Ne
- Jul 21, 2006
- Mike Neagle
I would like to get everyone’s opinion on my HT layout. In particular I am concerned about the placement of the projector. If you look at the layout it is located above the French doors at the back of the room. The doors are 8 feet tall and I have a 10 foot ceiling so I was going to put up a shelf for it to sit on. This would put the throw distance at about 18.5 feet. I plan on using a Panasonic AE900U. I was looking at a 106” diagonal screen. I will probably have to go with a high gain due to the distance. I plan on running all the cabling to the PJ from the front shelving through the ceiling and out at the back of the room behind the PJ. The seating postion is going to be about 10 feet.
Does this setup look like it will work without using too much correction from the PJ. The forward wall is 10 feet high. I was going to put the bottom of the screen 3 feet from the floor. The screen is 52” high. This would leave me with 32” from the top of the screen to the ceiling. Would this screen position work with the PJ mounted on the shelf above the doors?
http://www.avsforum.com/avs-vb/attac...chmentid=60766
