Projector Problem. Please help
Discussion in 'Displays' started by Larry Hoffman, Aug 20, 2004.
  1. Larry Hoffman
    Larry Hoffman Stunt Coordinator
    Jul 2, 2001
    102
    I borrowed an X1 from our supplier to show my daughter's wedding video at a party this Sunday. I hooked it up to check it out and immediately saw a bright white line right down the center of the image. It makes no difference if there is a video input or not, it is always there...right down the center of the picture. Its as if there was no image down the center. The line is bright light splitting the image in half.
    Any ideas about what is causing this? Is it something that can be adjusted? Or do I now have to find a projector tomorrow?
    Thanks in advance for your assisstance.
    Larry
  2. SimiA
    SimiA Second Unit
    Jul 26, 2004
    297
    If you're sure your connections are correct, and there's nothing wrong with the device your source material is coming from, I'd borrow another pj.
    Vb
  3. Larry Hoffman
    Jul 2, 2001
    102
    That's what I figured, especially when it's there with or without a source.
