BenBerentson
- Dec 16, 2004
New to the forum and I'm not sure if ths is the right place to post this messgae, but here goes. I need some help or advice with my Toshiba TDP-MT5 projector...when I try to turn it on, the fan seems to go on in a halfhearted way and nothing happens -- the projection lamp doesn't go on -- it just seems not to want to spool up. I doubt it is the lamp because i replaced that this year and when the lamp is broken, a warning light flashes. Here, all lights go on as normal. I'd do just about anything to keep from having to send the thing back to Toshiba only to then be told where else to send it. I feel like the fan is broken in some way, but the manual says a warning light would come on in that instance and it's not happening.
THanks,
Ben
THanks,
Ben
