Projector -- Infocus 4805 or Sanyo PLVZ2 (1 Viewer)
Chip Z
We are finishing our basement and adding home theater. Expect to be done by October.
I am considering the purchase of the DLP Infocus 4805 (approx $1399) or the LCD Sanyo PLVZ2 (approx $1700). (I would also consider other models under $2,000.)
96" screen. Probably sitting about 12-14 feet from screen. Will mount in ceiling. Room will be plenty dark.
I will mostly be using it for dvd, hdtv (thru cable box), xbox/ps2.
Ease of installation and use is important to me.
Suggestions?
GabeJ
Hey Chip,
You might want to wait until more people have seen the InFocus SP5000. It sounds like it's gonna be a great buy. It's what I am leaning toward, a local retailer is supposed to have one soon, I'll let you know what I think.
Check out the "Initial Thoughts Infocus SP 5000" thread at AVS Forums (I can't post links yet).
Mark Jolly
I have owned the infocus X1 then the Screenplay 4800 and now I have a PLVZ2. I have seen the 4805 a number of times and continue to be impressed. Having said that I would hate to lose the Sanyos flexibility of the shorter throw lens, the higher resolution and the vertical & horizontal lens shift functions.
As always these issues are not black and white but swings and roundabouts.
I will stick with the Z2 until i can afford a much better projector than either of the 2 being discussed.
Thomas Nichols
I have not seen the 4805 but my friend has a Z2. Super easy to install. Great HD pic. OK DVD pic. XBOX and PS2 look awesome through the component input. YMMV
daxlakin
