Projector help
Discussion in 'Beginners, General Questions' started by Mrinal, Oct 26, 2005.
  1. Mrinal
    Mrinal Auditioning
    Oct 25, 2005
    3
    Hi guys,
    I need some help with my projector. I want to watch cable tv on it, the only problem is it doesn't have a coaxial input. It has S-Video, AV and computer inputs, any suggestions as to what I can do?
    Thanks a lot!
  2. Jim Mcc
    Jim Mcc Producer
    Feb 11, 2004
    3,757
    38
    Oconomowoc, WI.
    Jim
    What projector do you have? You need to use your cable box as the tuner, then run your video cables to your projector. I do the same thing with my satellite receiver, OTA antenna, and my projector.
  3. Mrinal
    Mrinal Auditioning
    Oct 25, 2005
    3
    Hi Jim,
    Thing is I'm in a dorm room and don't have a cable box, I just have to attach the coaxial wire to a socket in the wall. Is a cable box the only alternative? If so, do you know where I can get one without subscribing to any cable service?
    Thanks a lot!
  4. drobbins
    drobbins Screenwriter
    Dec 2, 2004
    1,872
    110
    Dave
    If the cable signal is scrambled, you will need the cable box to decode. Otherwise a VCR might do the trick.
    Dave
  5. MikeCB
    MikeCB Extra
    Oct 25, 2005
    18
    Most of the time in dorms you would generally connect the coaxial cable directly to a TV, no cable box needed. But like drobbins suggested, a VCR can work as a tuner instead. Then you would run a composite or s-video cable from the VCR to the projector.
  6. Kevin_Spradley
    Kevin_Spradley Stunt Coordinator
    Jul 11, 2000
    171
    Your ultimate issue is that you do not have a tuner. The projector does not have tuner built in. Get a tuner either from the cable company or a VCR should work.
    BTW, sounds like a nice dorm room with a projector in it. I was too broke in college to have projector in my dorm room much less the size of the room was not condusive to a projector.
  7. Mrinal
    Mrinal Auditioning
    Oct 25, 2005
    3
    Hey guys, thanks a lot for your help! Will try and get it set up. Kevin, my room IS too small, but I got the projector as a prize, so just trying to make the most of it [​IMG]
  8. John S
    John S Producer
    Nov 4, 2003
    5,460
    Cheap stereo h-fi VCR is your cheapest answer, an SVHS model for a little better video quailty.
