Projector Height
Discussion in 'Displays' started by corona13, Aug 8, 2006.
  1. corona13
    corona13 Stunt Coordinator
    Aug 5, 2006
    105
    10
    Is there a minimum height a projector should be mounted at? I am in the process of constructing a home theater in my basement. Due to A/C vents and where I want my HT located, the projector has to be mounted under an A/C vent at about 6'10".
    Is this a problem?
  2. Brian Osborne
    Brian Osborne Stunt Coordinator
    Sep 2, 2005
    215
    as far as the height goes, depends on the projector. depending on your screen height, you would need to check with the manufacturer about keystone correction.
    I would worry about under an A/C duct. direct cold air can get condensation, and that can be very bad for electronics. Even if it isn't direct cold air, I'd still be hesitant about it...
  3. corona13
    Aug 5, 2006
    105
    10
    Thanks for the response...not too concerned about condensation...have had no issues with that.
    my main concern is being able to project the image at the desired height. any feedback on this?
  4. DelRay
    DelRay Stunt Coordinator
    May 13, 2002
    149
    If you FP has lens shift it should be OK. The lens height on my FP is about 6'5". And the top of my screen is about 6'3". Which projector are you interested in?
  5. corona13
    Aug 5, 2006
    105
    10
    Infocus IN76 and Optoma HD72
    thanks for the help
  6. Neil Joseph
    Neil Joseph Lead Actor
    Jan 16, 1998
    8,332
    Neil Joseph
    Moved to displays
