Projector cables through ceiling tiles
Discussion in 'Accessories, Cables, and Remotes' started by Jim Mcc, Aug 28, 2004.
  1. Jim Mcc
    Jim Mcc Producer
    Feb 11, 2004
    3,757
    38
    Oconomowoc, WI.
    Jim
    I want to build a DIY ceiling mount for a projector, and I need to know if I should run the power cord and component video cables separate? I was thinking of running them both in a pipe for the mount if it wouldn't cause interference. I want to hide cables as best I can. Thanks.
  2. Leo Kerr
    Leo Kerr Screenwriter
    May 10, 1999
    1,698
    I've often seen it done; many of the 'real' mounts encourage it - especially the motorized mounts. Though sometimes the scissor-lifts will have the power go down one side, the signals down the other. The last 'home-brew' mount I saw had power seperate, but that was a special case, too - power to the projector housing was in the form of two 3-phase 60amp/phase feeder circuits. The cage itself had two three-phase breaker panels...
    (granted, the projectors in question were Christie Roadie S-12 projectors; 3-chip 12000 lumen DLP large-venue projectors... four of 'em.)
    In my own case, with my really bizarre mount (combination of shelf and ceiling mount) I have power comeing in seperately. Given some of the other 'unclean' conditions that my signal cables are doing, I don't know if this really matters at all.
    Leo Kerr
  3. Wayne A. Pflughaupt
    Aug 5, 1999
    6,123
    40
    6,610
    Katy, TX
    Wayne
    This is generally frowned upon, but I think really “it all depends.” I would hesitate to do this for a long run, but if you’re talking about just the distance of the mounting pipe, it should be fine. After all, that’s why we use shielded cables for line-level signals, to reject EMI from things like power cords.
    Wayne A. Pflughaupt
