Will.MA
- Oct 23, 2004
I need advice in purchasing my first projection system. Here are some details to keep in mind while considering the best course of action:
1) For my tastes, contrast is more important than brightness. Also, I anticipate most viewing sessions in low-light environments.
2) occasional use only; projector will not be permenantly mounted
3) projector must have DVI input. Would strongly prefer 16:9 aspect ratio
4) source is HTPC; 1600 x 1200 max resolution via DVI
5) viewing distance: 10-12 ft.
6) intended use: 50% movies, 35% games (PC, Console), 15% TV (HD-Comcast)
7) budget: $2k max.
I've noticed while reading through the transcripts of past posts that many people have high praise for the infocus projector. However the impression that I have is that particular product doesn't support the DVI specification. Is there something else that's just as good? What guidelines should I follow when deciding on screeen size? I remember hearing somewhere that ideally the screen should be about half the size of the viewing distance. Is that so? Also, I like the idea of a pull-up screen that I can store away when not in use. Has anyone used a screen of this type? Lastly, both the HDTV and DVD source utilize DVI outputs. Any ideas on how to manage switching two sources for use on a display that has only one DVI input?
Thanks for any and all suggestions.
7) budget: $2k max.
