Progressive YPbPr to RGBHV converter
Discussion in 'Archived Threads 2001-2004' started by yekai, Oct 21, 2002.
  1. yekai
    yekai Extra
    Feb 27, 2002
    20
    Of course, you can choose Mitsubishi or KeyDigital.
    But here is the one I built.
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
  2. Craig_Kg
    Craig_Kg Supporting Actor
    Feb 25, 2002
    768
    Neat! How much did it cost in parts (minus circuit board, of course) and how well does this work with progressive scan sources?
  3. Jeff D
    Jeff D Supporting Actor
    Apr 6, 1999
    604
    yekai, hi
    I had just been asking about a DIY VGA->component transcoder, this sounds like almost the same in reverse.
    http://www.hometheaterforum.com/htfo...hreadid=102555
    Do you have plans for what I was looking for too?
    I'm also curious in price. The ST-TSH94 doesn't seem common. Where'd you find that? Pretty low cost.
    If you can help me too, thanks!
  4. yekai
    yekai Extra
    Feb 27, 2002
    20
    For frequncy response:
    That's depends on the OP AMP.
    I choose TSH94.
    The bandwidth of TSH94 is 150MHz.
    The most important is that the frequency response of this OP AMP is very flat.
    I have measured the output signal. 30MHz bandwidth is guranteed.
    For RGB-->YPbPr converter:
    Here is the thread:
    http://www.hometheaterforum.com/htfo...hreadid=126471
  5. yekai
    yekai Extra
    Feb 27, 2002
    20
  6. yekai
    yekai Extra
    Feb 27, 2002
    20
    [​IMG]
