Progressive, which one?
Discussion in 'Archived Threads 2001-2004' started by Tim Jin, Feb 3, 2003.
  1. Tim Jin
    Tim Jin Supporting Actor
    Jan 12, 2003
    529
    I like to get a progressive player, but I'm not too sure what to look for or which brands to consider. I have a Panny47 and a Panny nonprogressive player. Will I notice a big difference going to a progressive player? My budget is about $200.
    Thanks.
  2. Rob TT
    Rob TT Stunt Coordinator
    Feb 1, 2002
    111
    im kind of in the same boat tim, im trying to decide between the Panasonic RP62 ($110-150) or the Sony NS715 ($150)
  3. Jack Briggs
    Jun 3, 1999
    16,738
    129
    Tim: Can your display handle progressively scanned signals? JB
  4. Tim Jin
    Jan 12, 2003
    529
    I think, I hope so. Its a HDTV, pt47wx42. I am looking at the Panasonic 5 disc changer, DVD-CP67K.
    Any thoughts?
  5. Scott*CB
    Scott*CB Extra
    Jul 27, 2002
    21
    I have enjoyed my Toshiba 3109 for 3 years and it's going strong. I just bought a 3805 for my dad. Toshiba seems to have a very good combination of features/design/build quality for an affordable unit. I have also been very pleased with the picture on my Non-prog. player.
    The pannys also seem to be very popular here.
  6. Tim Jin
    Jan 12, 2003
    529
    My question is, will I notice a difference going to a progressive player???
    Thanks.
  7. Peter Loan
    Peter Loan Second Unit
    Oct 13, 1998
    355
    I've owned the Panny PT-53WX42 before with a DVD player capable of switching between interlaced and progressive modes on the fly. The difference was quite substantial as the Panny models do not have very good built in line doublers. The difference might not seem like night and day to some people but if you have the eye for it, you can spot the differences (less stairstepping, better color, smoother edges).
    Vanns.com has the JVC XV-SA600BK for $175 shipped. This player puts out a very nice picture, has a good set of aspect ratio controls, and handles layer changes quickly.
  8. Tim Jin
    Jan 12, 2003
    529
    Which player do you have? Are you using component out or s-video?
  9. Peter Loan
    Oct 13, 1998
    355
    Tim,
    Progressive scan only works through the component outputs. S-video only passes an interlaced signal so you'll have to pick up a set of component. I have the above mentioned JVC player for the time being.
  10. Tim Jin
    Jan 12, 2003
    529
    Thanks Peter for the tip. I just want to see what can the tv actually display with the right setup.
  11. Andy_SB
    Andy_SB Agent
    Jan 9, 2003
    46
  12. JoeEPTCB
    JoeEPTCB Auditioning
    Jan 14, 2003
    5
    I'm going to throw in the Tosh 4800 ($150) at Sears...very warm cinema look to it if you like that versus the sharpness of a Pana...it's DVD-A and has a great 4 step zoom feature.
  13. Rob TT
    Feb 1, 2002
    111
    I just picked up a panasonic CP72 from crutchfield for under $200 bucks shipped. This player has great reviews and I would check it out if I were you.
  14. John-Miles
    John-Miles Screenwriter
    Nov 29, 2001
    1,216
    3
    110
    Personally on my TV Toshiba 36HFX71 when i went from interlaced on the RP-91 ro Progressive i never noticed much of a difference, but then my set is smaller, and in my opinion has an amazing line doubler. So personally I am waiting to upgrade my DVD player till i can get a universal one and I am quite happy using my PS2 as a dvd player. (the RP-91 was borrowed forma friend)
