Progressive Scan with S-Video
Discussion in 'Playback Devices' started by Sanjivnpatel, Jul 23, 2003.
  1. Sanjivnpatel
    Sanjivnpatel Agent
    May 16, 2003
    28
    Hi ;
    Can anyone tell me if I must have a component video to enjoy progressive scan or I can get the improved results with S-Video out?
    I have old DVD player connected to projector through 50ft of S-Video cable. I am planning to upgrade my DVD player to progressive scan DVD player. Can I use the same S-Video cable and get the progressive results or do I have to get 50ft of component cable to get the better results.
    Thanks.
  2. Doug_B
    Doug_B Screenwriter
    Feb 11, 2001
    1,081
    You cannot get a progressive image sent out on the S-Video cable. The image will be interlaced, and your projector will have to do the de-interlacing. I think the amount of improvement in going component with a progressive signal to your projector will depend on your projector. For example, many newer digital projectors have very good de-interlacing. One must also take into account the quality of the S-Video cable you are using. If you are using a single, thin cable, image quality could suffer.
    Doug
  3. Lewis Besze
    Lewis Besze Producer
    Jul 28, 1999
    3,134
    DVD is a component video format,by using S-Video you bound to degrade the picture,even on interlaced players.
