Progressive Scan Players and Frame Overlap (1 Viewer)
ScottR
Can progressive scan players reduce or eliminate overlapping of frames on dvds? For example, if there was an error on the dvd where two frames were slightly misaligned, would a pscan player fix it?
John S
Can you clarify this a little better????
There is certainly bad edit detection, and it really does work on Faroudja based Progressive Scan players.
ScottR
Yes, say Frame One and Frame Two slightly overlap, causing a slight blur to the image if paused. When watched at normal speed, it almost appears to be a jump cut or a stutter.
John S
I do believe the bad edit detection feature would handle that well. Not all Progressive Scan players have bad edit detaction though.
jemes_kowalski_56
