Progressive Scan/Multi-Region question
Discussion in 'Archived Threads 2001-2004' started by John CW, Feb 2, 2003.
  1. John CW
    John CW Supporting Actor
    Oct 7, 2000
    619
    Hi! I was wondering if anyone could help me. I'm looking for a Progressive Scan Mult-Region DVD player that can output an NTSC compatible signal to an old NTSC TV from a PAL source.
    I seem to have found one at barrel-of-monkeys.com but I've never heard of the make :/
    Does anyone know anything about the R-Tech RJ3600? (http://www.barrel-of-monkeys.com/gra...rs/rj3600.html ) Or if not could anyone point me in the direction of a player meeting my specs?
    Thanks a lot!
    ~ Johnny
  2. Jeff Kleist
    Dec 4, 1999
    11,267
    All DVD players, progressive scan or not can output NTSC....
  3. John CW
    Oct 7, 2000
    619
    Oops! Thanks for pointing out my error -- In my haste I forgot to mention that I wanted to watch PAL DVD's on an old NTSC TV (which almost certainly isn't PAL compatible) until I upgrade to a HDTV.
    Still, if I could find a multi-region DVD player that was cheap and good quality (say around $300) I'd be happy for the time being at least! [​IMG]
    Thanks for any help!
    ~ Johnny
  4. Patrick Sun
    Patrick Sun Moderator
    Jun 30, 1999
    38,717
    463
  5. John CW
    Oct 7, 2000
    619
    Wow! Looks good! Any idea of the picture quality though?
    Thanks for the info!
    ~ Johnny
  6. Donnie Eldridge
    Donnie Eldridge Supporting Actor
    Jan 3, 2001
    761
    The Malata 520 does an admiral job when it comes to picture quality. The quality is much better than you would expect. If you could pick up the Malata flagship which is the N996 that would be the better route. However, they are no longer being made.
  7. Dmitry
    Dmitry Supporting Actor
    Nov 30, 1998
    740
    My friend has just ordered this JVC XV-S500BK. It should arrive next week and if you're interested I'll post the results when I get a chance to see it.
  8. Eujin
    Eujin Supporting Actor
    Mar 19, 2001
    549
    The JVC XV-S500BK is a fine machine. They are essentially the same as the Malatas, due to their use of the Mediamatics chipsets--this is what allows them to do the conversion from PAL to NTSC. However, having owned Malatas in the past, I'd recommend that you NOT get one due to quality control issues. That said, to be fair, Malata Canada who are the N. American distributor, always managed to come through with a replacement for me. I just couldn't stand the wait between shipping my player back to them and getting the repair/replacement. I currently use the JVC, with a region-free modification. It works like clockwork and I've been very happy with it. Picture quality on the Malatas and JVCs are pretty much identical. There are a number of places to find the region-free JVCs, but the two most popular are:
    www.jvbdigital.com
    www.hkflix.com
    I got mine from JVB Digital and only have good things to say about them. They will also modify your JVC for you if you already have one--good option if you can find a used one for cheap. Or if your soldering skills are good, you can simply get the kit and do it yourself. I am in no way affiliated with the company. Good luck!
