Progressive Scan DVD player: How much of a difference?
Discussion in 'Archived Threads 2001-2004' started by Brian Harnish, Jan 23, 2002.
  1. Brian Harnish
    Brian Harnish Screenwriter
    Dec 15, 2000
    1,216
    The subject says it all. How much of a difference would I notice on my Sony WEGA KV-32FV27 while using a progressive scan DVD player? Would it accept a progressive signal through the component inputs? Would there still be an improvement in the picture quality to warrant upgrading? I currently have a Pioneer DV-525.
    BTW, the player I'm considering purchasing (after my audio system) is the Toshiba SD5700 Progressive Scan DVD player.
  2. Marc Rochkind
    Marc Rochkind Second Unit
    Aug 26, 2000
    381
    If I am right (check me), this TV is not HDTV-ready. That is, its only display mode is 480i, not 480p or better. So, I don't think it can take progressive input at all.
  3. Chriss M
    Chriss M Second Unit
    Dec 14, 2001
    320
    that is correct, only the XBR series of Wega's will accept a progressive scan signal.
  4. Brian Harnish
    Dec 15, 2000
    1,216
    Does that mean that that player would be useless on my TV? Should I just stick with my Pioneer DV-525 until I get an HDTV-ready set?
  5. Michael Reuben
    Michael Reuben Studio Mogul
    Feb 12, 1998
    21,763
    3
    5,110
    I would, unless there was some other reason for me to upgrade my player.
    M.
