progressive scan can be done on the dvd player of the xbox
Discussion in 'Gaming' started by Jaden Wong, Jun 27, 2003.
Tags:
  1. Jaden Wong
    Jaden Wong Agent
    Jun 24, 2003
    27
    hey xbox owners check this out....
    i found out that u can enable the feature of progressive scan on the dvd player.....
    check it
    Here's something I collected from a website on how to do the progressive patch to DVDx2 and the MS Dash. I did it on both and it works great! I try to avoid my Toshiba progressive scan DVD player whenever possible now since the Xbox's DVD player works much better and in my opinion has better picture quality! Here it is:
    Thursday, 26, September, 2002
    Progressive Scan Dashboard / DVD Playback
    Posted by Sin-Tex at 23:12 PM
    News Source: XboxHacker BBS
    Open xboxdash.xbe in an hex editor
    search for : C7 46 28 20 00 00 00
    replace by : C7 46 28 40 00 00 00
    your Dash is now in progressive mode only
    Tested on a 3944 dash. ( Also confirmed to work on 4627 )
    Enjoy !!!
    Edited :
    For those without a DVD dongle, a little patch for DVDRegionX 2
    83 C8 02 C1 E0 04 -> 83 C8 02 C1 E0 05
    et voila it's progressive too.
    Check here for full details & info.
  2. BrianB
    BrianB Producer
    Apr 29, 2000
    5,205
    Which of course requires a modchip...
  3. Rob Lutter
    Rob Lutter Producer
    Nov 3, 2000
    4,523
  4. Jeff Kleist
    Dec 4, 1999
    11,267
    No, this is not a layman work whatsoever. First you need to chip your system, then you need to know what you're doing in a hex editor. If you don't know what a hex editor is, and what it's used for, and how to get one onto your Xboxen, you should not be attempting this
  5. Jaden Wong
    Jaden Wong Agent
    Jun 24, 2003
    27
    hey jeff i did the hex code thing on DVDX and when i play a dvd its just black but i can hear the audio... is this happening becoz i dont have component cables yet????
  6. Jeff Kleist
    Dec 4, 1999
    11,267
    Yes. You've set it to progscan ONLY which requires component AND a TV that can handle 480p
  7. Dave F
    Dave F Cinematographer
    May 15, 1999
    2,885
    2
    If you are using a mod chip, just download the progressive scan XBE and ftp it to the 'box.
    It might be possible to do this without a mod chip - by using the 007 saved game hole. I suppose that violates the DMCA too, though.
    -Dave
  8. Jaden Wong
    Jaden Wong Agent
    Jun 24, 2003
    27
  9. BrianB
    BrianB Producer
    Apr 29, 2000
    5,205
  10. Scott L
    Scott L Producer
    Feb 29, 2000
    4,457
    The xbox DVD player is nice, but I and many others have been complaining how dark the picture is. I'd rather just spend $200 on a dedicated standalone so I wouldn't have to open my console and install some wacky chip, while putting a future XBL account in jeopardy.
  11. Michael St. Clair
    May 3, 1999
    6,001
    The XBox is no darker here than my DVD player at 0 IRE.
    The progressive could be nice in a pinch, but the XBox has the chroma bug and the deinterlacing isn't as good as the Faroudja and Silicon Image chips in many progressive DVD players.
    I've got some aquaintances who use chipped XBoxes to play MAME and other emulators with no Live problems, they just use a switched chip.
  12. Dave F
    May 15, 1999
    2,885
    2
    Although I haven't made my Xbox a progressive player, I've read that it is purely flag based, which pretty much kills my interest. Lots of excellent players for low prices these days.
    -Dave
  13. Jaden Wong
    Jaden Wong Agent
    Jun 24, 2003
    27
    hey brian
    so my tele only supports 480p????
    does it support 720i or 1080i??
    i dont eve know what they r???
    i cant eve find the FAQ page of this website
  14. Jeff Kleist
    Dec 4, 1999
    11,267
    Your TV only support 480i- standard NTSC (I assume supports PAL as well)
    720p and 1080i are ATSC HDTV resolutions.
    Basically, you need to unfix your player if you can, and if you have made it 100% progressive, you've busted your box unless you can find someone with an HD set to reset it
  15. Jaden Wong
    Jaden Wong Agent
    Jun 24, 2003
    27
    i dont understand what u mean
  16. Jeff Kleist
    Dec 4, 1999
    11,267
    Here is the HDTV overview from the FAQ
    http://www.hometheaterforum.com/htfo...754#post523754
    Simple explanation
    NTSC, the standard US TV format is 30 frames per second. These frames are drawn on screen in a fashion called "interlace". This means that first the TV draws the odd numbered lines, then the even like this
    3
    5
    7
    9
    and so on
    and then
    2
    4
    6
    8
    10
    and so on
    It completes drawing the whole image 30 times in 1 second, resulting in 30fps
    This can result in jaggy images. PAL (Australia/UK/most of Europe and South America) standard) uses the same basic process, except it's only 25 frames per second
    In progressive, these frames are drawn all in 1 pass
    2
    3
    4
    5
    6
    7
    8
    9
    10
    By doing this, you get a smoother image, especially good for gaming. However, only newer TVs, mostly HDTV models support drawing the image progressively
    Normal NTSC is 480i meaning there are 480 horizontal lines, and they are drawn on screen using interlacing
    480p is the same deal, except it's drawn progressively
    720p uses 720 horizontal lines resulting in a higher resolution image. And draws its image progressively
    You MUST have an HDTV for this resolution.
    1080i is the top end of HDTV at the moment for the consumer level and uses interlacing with 1080 horizontal lines.
    Any mode but 480i REQUIRES component cables, and requires that the TV supports it. Usually you will only find 480p and up in HDTV models.
    My hacking your Xbox to show the dashboard and DVDs progressively, they will not display unless you can support it. Since your TV doesn't appear to support progressive, you can't watch your DVDs
  17. Jaden Wong
    Jaden Wong Agent
    Jun 24, 2003
    27
    i just recieved my hdtv pack
    i have a pal box and my tv is not hdtv
    ok i went into m$ dash and turned on to 480p
    does that mean i play games at 480p with the games that support it?
    i tried using the progressive scan dvdx2 but when i run the dvd it just outputs black screen is this because i have a pal box and cant utilise the progressive scan?
    b4 i stuck component cables into the xbox what type of resolution did it run on? after u put it component does it run on 480i on defualt?
  18. Jeff Kleist
    Dec 4, 1999
    11,267
    Your TV does not support progressive scan as I've been telling you. Component does not equal progressive or HD
  19. Jaden Wong
    Jaden Wong Agent
    Jun 24, 2003
    27
    then how come u can purchase progressive scan dvd players that can work on normal tv
  20. Jaden Wong
    Jaden Wong Agent
    Jun 24, 2003
    27
    hmmmmm
    how much of a difference should i be getting when using component cables....
    words r more viewable and more sharper...colours r more brighter and images the outlines dont have fuzzy outlines
    am i right high priest?
