Progressive Humm with my SVS?
Discussion in 'Archived Threads 2001-2004' started by Earl J, Jul 5, 2002.
  1. Earl J
    Earl J Stunt Coordinator
    Aug 23, 2001
    101
    Had the humm from day 1 when I received my SVS/Samson. Disconnected my Cable and sure enough, the humm went away. At first I thought that the Rat Shack Ground Loop Isolator had solved my humm problem.
    Now, when I turn on my amplifier (Samson 700) there will be usually be no humm at all. But about 30 minutes into a movie I'll start to hear a faint humm from my SVS 2039CSi. After about another 15 minutes or so, the gets louder and then louder. If I turn off the amp for a minute and then restart it, sometimes the humm will either go away, or the humm may be reduced a bit. About 10% of the time, I can go through a whole movie without hearing any humm. Any thoughts?
    My equipment:
    Denon 3802
    Samson 700
    SVS 2039 CSi
    ART 351 EQ
    Mits 65908 RPTV
    Thanks for any assistance.
  2. BryanZ
    BryanZ Screenwriter
    Dec 18, 2000
    1,214
    110
    Email SVS. Looks like you may have a problem with the Samson.
  3. John F. Palacio
    John F. Palacio Supporting Actor
    Jan 6, 2002
    575
    I second BryanZ.
  4. SVS-Ron
    SVS-Ron Screenwriter
    Jun 2, 2001
    1,074
    Or a problem with the GLE.
    Earl, in those instances where the hum gets louder, have you tried to disconnect the cable again? What happens?
    Also, have you tried a "cheater plug" at any point?
    Needless to say, if the Samson seems to be the culprit here it's going to get replaced, we just want to ensure there's a high probability it's not still a ground imbalance/interference.
    We've never had a Samson exhibit what you describe so I've got a sneaking suspicion it might not be the issue.
    Ron
  5. Earl J
    Aug 23, 2001
    101
    Thanks Ron. Tom emailed me some suggestions that I'll try out over the weekend. I'll let you know how it goes.
  6. Todd_Petersen
    Todd_Petersen Stunt Coordinator
    Oct 4, 2002
    161
    What ever happened with the hum noise? how did you fix it?
  7. SVS-Ron
    Jun 2, 2001
    1,074
    99 cent cheater plug on the Samson if I recall correctly.
    "Could be wrong... but I doubt it."
    Ron
