Progressive DVD player for my Toshiba HDTV (1 Viewer)
Neil Middlemiss
Neil Middlemiss
What is the best Progressive DVD player that I can get for under $400 that will work best with my Toshiba 65H81? I have looked into the Panasonic RP-56 and DVD CV51 but I am open to any suggestion to get the absolute best picture that I can afford.
Dan Driscoll
The new TOshiba SD-4700 and 5700 have gotten some good reviews, along with the JVC XV-S60/70 models.
But if you can stretch your budget a little higher, the Panasonic RP-91 can be found for less than $450 on-line, if you shop around. A lot of people think this is the best DVD player available for under $1K.
Dan Hitchman
I concur with the other Dan. It's well worth it to bump up to the Panasonic RP91. Overall, so far, the best bang vs. buck.
Dan
Jeff Brooks
Sugar Hill GA USA
Jeff Brooks
I have a Toshiba SD-6200 that I love. It is connected to my 65H80. It does not have DVD-A; but, it handles two discs. Since it is last year's model, I would bet that you could get one real cheap.
Thomas_Berg
Dallas
Thomas
Panny RP91.
i bought it with two DVDs and i talked the J&R guys down to $440 shipped for it all! best deal i've ever gotten!
NHCondon
