Progressive DVD and s video
Discussion in 'Archived Threads 2001-2004' started by Ronald K, Nov 19, 2001.
  1. Ronald K
    Ronald K Auditioning
    Nov 6, 2001
    4
    Using an s video connection, is there any value in upgrading to a progressive scan DVD player or does the improvement need a Component Video connection?
  2. John Kotches
    John Kotches Cinematographer
    Mar 14, 2000
    2,635
    This is an easy one.
    Progressive scan can only be sent via Component Video or RGB, not via S-Video.
    Plus, the TV has to support progressive input [​IMG]
  3. Scott Merryfield
    Dec 16, 1998
    12,312
    1,068
    9,110
    If your television can only accept an s-video connection, it is not capable of receiving a progressive scan video signal. As John mentioned, progressive signals are sent via either component or RGB video connections. That being the case, you can still use a progressive scan DVD player with your TV, since the player will also have s-video and composite video outputs. However, these will be standard interlaced video and offer no increased video performance over a comparable interlaced-only player.
