jimtheeagle
- Dec 23, 2015
- James Reid
I have a URC MX-780 and the installer says he recommends only programing it to open each input device i.e. a Smart TV button, a Apple TV button, a Roku button etc...
What I would like to do is have a Pandora button, a Netflix button, a Cable TV button etc...
The installer says this is possible using macros but is unreliable because what happens is you program SmartTV>Apps>right push>right push to give say Pandora. If there is an update or Pandora gets moved in the menu then the button is directing you to the wrong spot.
Is there a way to program the remote so that it goes directly to these apps?
