Program for FLAC or SHN files
Discussion in 'Computers' started by Dan Joy, Oct 10, 2004.
  1. Dan Joy
    Dan Joy Supporting Actor
    Dec 8, 2001
    758
    I have quite a few concerts downloaded on FLAC and/or SHN files. Are there any free programs to:
    1.convert these to MP3 and retain the naming files (assuming there are naming files incorporated)?
    2. Should I first convert these to wave then use EAC to mp3?
    3. Do you have any suggestions for ease of use?
    Dan
  2. JoshEE
    JoshEE Agent
    Aug 20, 2002
    34
    I can't be any help with the shn files but here's a link to the free program i use for flac files. Hope it helps.
    -Josh
  3. Tekara
    Tekara Supporting Actor
    Jan 8, 2003
    783
  4. NickSo
    NickSo Producer
    Jul 2, 2000
    4,260
    Nick So
  5. Herschel
    Herschel Stunt Coordinator
    Jan 30, 2004
    94
    I second the dbpoweramp recommendation. You can get Shorten and FLAC plugins for it, and it'll encode with LAME right to MP3 from SHN or FLAC.
    There's also a shn2mp3 script out there (I think it's Perl, not positive) that'll convert a directory at a time, and attempt to get info from the text info file to plug into the ID3 fields. It's in the etree-scripts package.
  6. Mike Fassler
    Mike Fassler Supporting Actor
    Jan 17, 2004
    523
    yep Db power amp is the way to go.
  7. Dan Joy
    Dec 8, 2001
    758
    Thanks to all!
  8. Chris Pravetz
    Chris Pravetz Auditioning
    Oct 10, 2004
    2
    mkw Audio Compression Toolkit will batch convert SHN files to/from MP3 and WAV format. It's donationware. This forum won't let me post the URL since I haven't written enough posts yet. Google should find it for you.
