Dave Schofield
- Sep 30, 1999
I currently have a I have a Dell Dimmension XPS D300 (P2-300) that I bought four years ago. Since I'm pretty attached to the machine I'm going to try to coax two more years out of it. I don't play many games, though I'd like to have a shot at playing Warcraft 3 it comes out (if it ever comes out).
I see on Pricewatch that I can pick up a P2-450 that looks like it will work with my motherboard. I'd rather not mess with installing a new mobo, but I can if it is really worth it (and have in the past on other computers, so it wouldn't be a complete adventure). The P2-450 is ~$90, whereas I'm sure mobo+processor are quite a bit more expensive.
Anyway...
Since I'm looking at upgrading my processor, I immediately thought to look through the BIOS and see if it would support the P2-450. Unfortunately, it doesn't appear that it does. I can only select speeds of 266, 300 and 333mhz. Will this selection change if I put in a new processor, or do I need a new BIOS? If so, where can I get one? My warranty has been up with Dell for some time now and doubt they'd even talk to me about my computer without charging me for it.
Circling back, does the BIOS problem illustrate that I should just go with a new mobo (extreme newbie question: is the BIOS on the mobo, or elsewhere?)? If so, which one? I'm not even sure what style case I have...
Thanks!
Anyway...
Thanks!
