Problems with Samsung TXM3297HF
Discussion in 'Archived Threads 2001-2004' started by KennyJ, Oct 28, 2002.
  1. KennyJ
    KennyJ Auditioning
    Apr 18, 2000
    I just got this TV last week and am already experiencing problems. On the right side of the screen, in particular the bottom-right corner, the picture is dark and there is noticable color bleeding. Also this part of the image is not as sharp as the rest of image. Is there any way to get rid of this manually? If not, should I: a.) Contact Samsung or b.)take it back to the store for a replacement. Any info would be greatly appreciated.
  2. Cooper_B
    Cooper_B Agent
    Sep 26, 2002
    38
    I say if you're not happy with a product, return it. It sounds like Samsung is having some quality control issues with its small HDTV monitors, and I would think it impossible to fix problems with one small region of the screen.
    Still, I will probably get the 2797HF soon. You can squeeze/unsqueeze progressive inputs, right? Any other comments on the screen?
    -Cooper
