problems with nero 5.5.9.9 and XP
Discussion in 'Archived Threads 2001-2004' started by Patrick_M, Jan 2, 2003.
  1. Patrick_M
    Patrick_M Stunt Coordinator
    Dec 3, 1999
    96
    I recently upgraded to Windows XP Pro. I have a 1.3 ghz Athlon and 256 meg of pc133 ram and a 80 gig hard drive. When I was running windows me, nero worked fantastic...the buffer level never dropped below 91% (I have a TDK Velo CD writer 32x with buffer underrun protection) Now on XP the buffer jumps back and forth like a yo-yo, and nero prevents 60 or 70 underruns per disc!! So now a cd that used to take 3 or 4 minutes to burn is taking almost 10 or 11 minutes! Are there some settings that I need to change to get nero to work better? I downloaded the lastest version of nero from the velo cd support site, it says it is compatible with XP. So any suggestions would be appreciated...I like XP a lot and dont want to go to back to ME just for burning.
    Thanks everyone in advance for your suggestions.
  2. Gabriel_Lam
    Gabriel_Lam Screenwriter
    Mar 7, 2002
    1,402
    Does 5.5.10.0 do the same thing?
  3. Chris Luebbe
    Chris Luebbe Auditioning
    Dec 31, 2002
    12
    I'm using 5.5.4.0 under XP Pro and it works fine. I'm using a 32x Toshiba reader, a 6x Yamaha writer, AMD 1800+ CPU, 512MB RAM. I don't think your hardware is an issue.
    Is the upgrade really a full installer and not just an upgrade? If so, you may want to try completely removing Nero first.
    Are you copying CDs on the fly or burning from files on your hard drive? Maybe your "source" CD drive is the problem?
    Are you running several memory/CPU intensive tasks at the same time? Two or three "modest" apps like IE or Office or whatever might be fine, but trying to run CPU hogs like Photoshop, Fireworks, or Flash might be causing the problem. Check your task manager and see if there are programs eating up your CPU in the background.
    I hope I got you pointed in the right direction...
  4. MikeyWeitz
    MikeyWeitz Supporting Actor
    Feb 10, 2002
    939
    Did u do a fresh format and install of XP or did u upgrade from a previous version? If upgraded froma previous version, I HIGHLY recomend doing a fresh install, it will solve 99% of any problems u have after the upgrade, NERO included.
