Problems with Digital Natural Motion
Discussion in 'Archived Threads 2001-2004' started by Mikko-Ville, Mar 26, 2002.
  1. Mikko-Ville
    Mikko-Ville Stunt Coordinator
    Mar 25, 2002
    69
    Hi!
    Has anyone had any problems with the Digital Natural Motion when wathing DVDs? DNM is a new feature on Philips TVs which should make all the motion in the picture look very smooth and natural.
    My problem is when watching DVDs with Digital Natural Motion on it tends to make all motion look very unnatural [​IMG]
    When turned off the picture looks normal.
    Any similar problems anyone?
    My TV is Philips 32PW8807.
  2. Allan Jayne
    Allan Jayne Cinematographer
    Nov 1, 1998
    2,404
    I would not be surprised if they tried to do some blending of adjacent field or frame content so that any jerkiness inherent to just 24 frames per second gets smoothed out. This would be moving in the opposite direction from 3-2 pulldown detection and optimizing during conversion to progressive scan.
    Video hints:
  3. Christopher Bosley
    Christopher Bosley Stunt Coordinator
    Aug 2, 1999
    101
    My experience has been that Natural Motion is pretty good for smoothing out my cable channels but I never use the non-HD input for watching DVDs. Dunno if you HAVE an HD input on your model but a progressive scan DVD player into one makes all the difference.
  4. Mikko-Ville
    Mar 25, 2002
    69
    The jerky motion is lot more noticable on PAL (R2, R4)encoded dvds. I don't really notice it on NTSC (R1) encoded ones. Perhaps it has something to do with the PAL speedup compared to NTSC?
    PS. I don't have a HD input on my TV.
  5. Bill Slack
    Bill Slack Supporting Actor
    Mar 16, 1999
    837
    I'm assuming it's supposed to smooth the 24->30fps conversion?
    PAL shouldn't be jerky at all. Like you said, it's just 24fps played @ 25fps, so it should be as smooth as it was in the theater (albeit, 4% faster!). Maybe it's trying to smooth out things it shouldn't and is causing weird things to happen??
    Is it something that can be disabled?
    P.S. Welcome to the Forum! [​IMG]
  6. Mikko-Ville
    Mar 25, 2002
    69
    It's really weird because the jerkiness doesn't seem to be there with NTSC encoded dvds. With PAl encoded dvds the jerkiness varies from just noticable to very annoying.
    Fortunately it can be turned off. Though it actually makes the picture look better if it wasn't for the jerkiness. When there isn't much happening on the screen the picture is nice and sharp but when people for example people start moving fast it looks the director has put a really funky effect into that scene.
    P.S Thanks for the welcome! [​IMG]
  7. yekai
    yekai Extra
    Feb 27, 2002
    20
    Does it has progressive scan input?
    If so, it's much better to use a PDVD player.
    As I know, only a few 100HZ TV has 3:2 pull down when they do de-interlacing.
  8. Mikko-Ville
    Mar 25, 2002
    69
    No progressive scan input. [​IMG]
