Problems with a couple of disks with CC in my Toshiba SD510
Discussion in 'Archived Threads 2001-2004' started by AlbertAgullo, Sep 23, 2002.
  1. AlbertAgullo
    AlbertAgullo Agent
    Mar 28, 2000
    42
    I bought two Cary Grant films: "Grass is greener" and "Indiscreet" which are supposed to include Closed Captions, but my Toshiba SD-510 does not play them (The CC I mean).
    Anyone heard about this problem?
    Are different types of CC?
    Is it a player malfunction?
    Regards
  2. Darren D
    Darren D Stunt Coordinator
    May 23, 2001
    51
    If you have progressive scan, try disabling that. I found out that allows the CC signal to go through for me if my discs are not subtitled. Normally, though, I use english subs.
    Hope it helps...
