Problem with XP Crashing
Discussion in 'Archived Threads 2001-2004' started by Kevin_Graham, Mar 29, 2002.
  1. Kevin_Graham
    Kevin_Graham Stunt Coordinator
    Mar 1, 2001
    131
    When I turn on the guest account and then later switch back to my account to turn off the guest account XP crashes with a message saying that it's saving everything from memory to the hard drive. This is a new problem because I was able to manage the guest account earlier without XP crashing. How do I fix this? Is a re-install my best option?
  2. Neil Joseph
    Neil Joseph Lead Actor
    Jan 16, 1998
    8,332
    Neil Joseph
    Have you tried restoring from a date prior to the problems?
  3. KyleS
    KyleS Screenwriter
    Jul 24, 2000
    1,232
    As Neil stated XP does have a kind of Go-Back software that is installed when you install the OS. The Go-Back software is defaulted to on unless you turn it off manually. If you disabled the software then you may want to try a OS repair from the CD.
    KyleS
