problem with Toshiba 42H83
Discussion in 'Displays' started by david*mt, Jul 27, 2003.
  1. david*mt
    david*mt Second Unit
    Dec 11, 2002
    306
    I have noticed three transparent bands that appear on the screen from time to time, mostly during brighter scenes. One is seen horizontally across the center and the other two are vertical. Is there something wrong with my TV? I was watching Dances with Wolves last night and whenever the blue sky is in the movie I can see the lines. It is very distracting. I tried different dvd players and even different cables but nothing helps. Any suggestions? I doubt Toshiba will be of much help.
  2. Nick V
    Nick V Second Unit
    May 7, 2002
    421
    Are you still within your return period? You may just want to try and get your unit swapped out for a new one, to see if the problem re-occurs.
  3. david*mt
    Dec 11, 2002
    306
    I contacted Toshiba and they said that the transparent bands are not a problem they are aware of and suggested I have a service tech come look at it since it is still under warranty. Should I do this and is there a good chance they can fix the problem?
  4. Richard Travale
    Richard Travale Producer
    Feb 27, 2001
    3,425
    12
    The Island, Canada
    Rich Travale
