Problem with Speaker? Please Help!
Discussion in 'Archived Threads 2001-2004' started by MarceloC, Nov 30, 2002.
  1. MarceloC
    MarceloC Auditioning
    Nov 24, 2002
    4
    I've just bought the Sound & Vision Home Theater Tune Up to calibrate my new system.
    During the speakers tests I can hear a weird vibration in ONE surround, the other one is fine. I tried to move the surrounds from left to right and the problem remains in the same surround (so it should not be the cable).
    The problem is that I can notice this weird vibration in one surround only during the S&V Tune Up; I cannot notice it anywhere else.
    Is it a problem? Should I take it to the service center? I've just got my system a few days ago!
    Thanks.
    My System:
    Infinity Entra Point Five HTS
    Denon 1803
  2. Marc H
    Marc H Second Unit
    Aug 22, 2001
    497
    Could the binding posts or mounting screws be loose?
    If not, can you tell if it's coming from the woofer or the tweeter?
  3. MarceloC
    Nov 24, 2002
    4
    Marc,
    I've just noticed that the vibration is in the tweeter. The vibration stops if I remove the grilles and smoothly press the tweeter with my finger. It restarts when I remove my finger.
    Does this indicate anything?
  4. Brent_H
    Brent_H Second Unit
    Aug 14, 2002
    366
    I had that sort of problem with my right rear using the S&V disc also...but I think its cause my speaker is sitting on a coffee-sort-of-table and loose screws and what not are sitting on it [​IMG]
